The denso part number should be on a plate on the side of the pump. Visible with a mirror if still on the engine. If you need the valve numbers these can be traced from the main number.
From what I seen there are several different injector pump OEM numbers depending on the year and engine configurations, and potentially geographical region. My understanding is that any 12 valve should work for a 12 valve but that the 24 valve is different from the 12 valve (Some one told me that a 12 could be adapted to a 24 valve if you really have the motivation).
Here are the HDJ80 OEM injector pump numbers that I have collected previously:
12 valve (1HDT)
Denso 096000-8581 (Toyota 22100-17590)
24 valve (1HDFT)
Denso 096000-9761 (Toyota 22100-17881 or 22100-17880)
