Hi,
Time to change the diesel filter on my 1999 100 diesel, got a new genuine Toyota filter all ready to go when I noticed the previous owner had fitted what looks to be an incorrect filter without the water drain valve, its a closed canister type, made by "Boshi".
The new Toyota one has a hole in the bottom for a water drain valve, I also found a 2 pin plug under the filter that looks like it should have had a water in fuel sensor attached to it at one time.
Do I have the correct Toyota filter with the hole in the bottom?
Am I missing the drain valve with an in build water in fuel sensor?
Lastly how does the system work?
When I turn the key on there is the amber warning light that comes on for a few seconds then goes out so the dash bulb etc must be good, however what looks like the sensor plug has an open circuit (nothing attached) when I shorted the 2 pins in the plug with some wire the lamp did not come on, so not sure where I am with the system???
Thanks in advance
Thanks in advance
