Diff & Transfer Box plug washer size
Buller
I'm changing the oil in the rear differential and transfer box. Any idea what size the drain and fill plugs washer sizes are?
I bought new plugs from roughtrax and i'd guess the measurements will be shown in their specifications tab ?
From memory they're 21mm but as Shayne says, it's probably better to buy a new set of filler and drain plugs - as you'll probably end up butchering them both if they haven't been undone for some time!
BTW - the front diff has a different setup with hex socket plugs and they can be different sizes for drain and filler!!
Thanks for the advise, I'll hold of rough trax tomorrow and see if they have the bits.
