As I'm sure you've mentioned before, get the underside as clean as possible, removing any wheel arch liners, mudflaps, bumpers etc that can hide areas, or trap dirt, then let the vehicle dry out.
Clean back any surface rust and treat the area with Dinitrol RC900 rust converter/stabiliser, this is great stuff.
Use newspaper and mask anything on the underside of the vehicle that you don't want to cover, exhaust, heat shields, coolers, rad, suspension etc. Then bag the whole car, masking up all the wheel arches, sills and sealing all areas that overspray could possibly get through and onto the vehicles bodywork. Halfords sell the body shop sheets/bag to cover the body, as well as the same stuff on a reel as well, well worth using.
Seal all the holes/access points to the engine bay in the inner wings, masking tape over holes and newspaper on larger areas normally help with this. Also mask the chassis number if your going to be shipping/taking the vehicle out of the country, so that its still visible after the treatment. Once the inner wings are sealed, cover the engine bay with an old blanket and close the bonnet, otherwise when spraying up, overspray can find its way past a bonnet that isn't fully closed.
The 1litre cans in my experience work very well with the Dinitrol supplied spray gun, and give good coverage. After cleaning back any surface rust and treating with RC900, I spray all the body and chassis box sections with cavity wax. Then spray all the outer surfaces (chassis, vehicle underside and axles) with the black underseal. You'll find that you'll need to spray this from many different angles, and over a couple of goes to get a full and good coverage. It's easy to miss areas or faces of contoured panels on the first go, a good light will help you to see the vehicle through the mist.
Let the black underseal dry overnight and then apply the stone chip to all areas that are likely to get blasted by stones, wheel arches, sills, front face of the rear axle and lower rear quarter panels.
Now you can unmask the vehicle and turn your attention to the doors and under bonnet areas. To get the best coverage inside the doors it's best to remove the door card, I tend to do this when I have a reason to go in there, and spray cavity wax around the doors structure, the cavity wax does come in areasol form which can help on this job.
Under the bonnet I use the high temperature wax to coat the inner wings, underside of the bonnet including the box sections and the slam panel. This wax also comes in areasol form, and it's well worth putting a sheet over the windscreen and taping sheeting to the wings to prevent overspray.
Preparation is the most time consuming part of this job, but it makes the world of difference in the end result. I would recommend wearing disposable overalls, a hat, googles and a good breathing mask. Plus be concicous of where any overspray might end up.
Enjoy.
