Do you get SD to USB adapter
Graham
SD to USB.
Not USB to SD
Are they made?
Gra
Could be made. Might have to be a device to put into a cig.lighter socket tho', to give enough power to run a usb device. Who's volunteering? Would be a great gadget.
Most micro sd cards come with a normal sized card case so micro can be used in phone or with the case in pc .
hi all,
I have found in the past, reverse data transmission does not work on micro sd cards, in a SD adapters.
Recently had a case with phone to camera reverse data.
It would only work if I took the micro sd out of it's carrier.
I can't copy and paste but if you just search for an SD card you will find a micro card for phones which can be taken out and slotted into a normal size SD card to transfer data to a pc . I'm guessing but i don't see why you couldn't get that micro mobi usb adapter , plug it into the micro to normal adapter and Bobs your aunty Mavis .
