I think there’s a lot of luck involved in the quality of the batteries you get when you buy new irrespective of the brand. The two Vartas on the 80 when I bought it were not new but still lasted me 9 years despite being flattened to within an inch of their lives twice due to a parasitic drain fault. The current replacement Vartas are almost 5 years old now and still going strong.
I put a new Varta on the dirt bike last year but left the heated grips on which flattened it to less than 6 volts which effectively killed as it wouldn’t hold charge despite being ‘recovered’ by a fancy charger. Only takes one weak or bad plate and the whole thing is scrap.
Steve ask your self how many vehicles, in freezing climates, are 24v? Ask yourself why the 100 series is 12v. Ask yourself why the Colorado only came with the 2 battery Winter pack - in the UK. ask yourself why only the LWB Colorado got the Winter pack. Ask yourself why the 4.5 petrol 80 only came in 12v. Why is the 70 series 12v?
If an 80 doesn't start in 1/4 second, then it's not going to start. Any 12v Landrover, Rangerover, Patrol etc will use more cranking in hot weather than a sub zero 80 would in the Arctic. It's completely unnecessary.They fire up like a light bulb every single time
You see the case for 12v start has been made. It works. it's the same as a billion other cars in the world. So far (and having owned 5 80s) no one has ever said, crikey, it's a good job the 80 was 24v or it would never have started.
You can always tell a new 80 owner. How, becaue they don't let go of the key fast enough.
Fight fight fight ....
Just wondering why they ever did the 24v starter, I agree it's not needed but wondering why Toyota thought it was even a good idea.
im doing well if I get five years out of a set of varta'sSee what the voltage of each battery is on cranking in the the morning?
Sick to death of batteries. Had the 80 20 years now and never had a pair last more than 3 years. Even the originals failed dead on 3 years 1 week after I bought it. Never a slow crank warning but just a click. Better than a big end click though.
The 24 volt system doubles the chance of battery failure c/w 12 volt system. Also in the event of failure you have to buy 2 batteries rather than one. My conversion allows me to still have 2 batteries but I only have one connected at a time. I just undo the coupling on the battery in use and connect up the other one every few weeks or so to rotate them. This means I have a more reliable system than 24 volt and in the event of failure have a spare fully charged one already fitted.
Just had battery failure on my 5 year old Golf. Halfords offered a 4 year warranty with their battery but main dealer only 2 years. Mystifying and very expensive with a bill for £220.
That's the easiest question ever Steve. I would not know where to begin . But you are adding more stuff aren't you ?
P.S. Just checked Halfords 'site they show an 80 battery with five year warranty. I assume they can get the handed one. Not cheap at £124.
