Driver's door armrest switch control plate
Hello
Anyone know if I can get a drivers door armrest switch control plate - the
removable piece with the window and locking switches on it... After the
broken glass saga last week I've now discovered the rear plastic lug has
been snapped off by the guy who replaced the glass. Wish I'd done it myself
now but still... It now won't sit in place but I could always use strong
double-sided. Just wondered if I could get one (in grey) and if they were
cheap...
Jeremy
HDJ81 1993/4, with some of the usual suspects
Jeremy Llewellyn-Jones
Mob: 07831 458 793
Jeremy,
If you are talking about just the top plate to which the switch
assembly is bolted, it's part No
74231-60010-03 or 74231-60070-B0. Check the price with Toyota as car
breakers will probably want to sell you the whole assembly switch for
70 quid.
Maybe UHU plastic glue will do the tric. It did on mine.
Rgds,
Roman (London, UK)
'92 HDJ80
On 2/27/06, Jeremy Llewellyn-Jones <[Email address removed]> wrote:
e
lf
You're probably right Roman - a bit of glue... If I had done it myself
that's what I'd do so maybe I should go ahead. Uhu is easy to break if you
need to get in there...Just annoys when you let someone else loose on your
car and they break things...Thanks for the parts numbers.
Incidentally I am yet to find a good breaker in the nearish vicinity.
Jeremy
Mob: 07831 458 793
Hello Jeremy,
A alarm installer broke the steering column surround on one of my
previous car's I got a quote off Toyota and then went back to them and
told them they were ordering it and I would install it as I did not
trust them.
If the window guy broke it make him supply a new one.
Craig Vincent
HDJ80 VX LTD Auto, 11/96
Maartens transcooler, Sport turbo & intercooler, Rodney's Extreme II
Valvebody, 3.5" Flowmaster, Walbro 6065, Bilsteins, pyro, boost, pre &
post intercooler, & transtemp gauges
Christchurch,
New Zealand.
Jeremy Llewellyn-Jones wrote:
Craig
Funny you should say that - as I was sitting at home writing away, I called
Autoglass, the guys who replaced the glass, they sent someone out to have a
look, they then called me from their local outfit to say that they had
ordered the part and that I would have it on Thursday. They even called back
to check that they had ordered the right colour. So Hopefully all sorted.
Thanks for the thought -
By the way, did you get all the mods for your car in NZ?
Jeremy
Mob: 07831 458 793
