Hi,
I have just had my engine cut out and cannot get it started, I
need some info./help.
1HD FT engine, auto box, towing a caravan. 60 MPH and suddenly
the engine lacked any power, I thought of switching to 2nd but the
lights on the dash were on as pre ignition so I pulled off the road.
Engine will not start now, it turns over fine. The A/C drive belt was
broken but I believe this to be coincidental.
I have checked the fuel cut off solenoid (on the pump) and it
seems to be OK. I have also tried re-setting the ECU with the fuses
out., and the batteries off. All fuses are sound. Fuel pump is not
delivering fuel. Is there any other solenoid for the fuel supply? I
cannot believe that the pump has failed so suddenly at 110,000 miles.
Any help/suggestions would be appreciated. Thanks.
Regards, Clive Marks.
