Engine losing revs after rocker cover gasket replacement
cjb80
australia
I just had rocker cover gasket redone.
Now when I drive, if I hit accelerator hard, the engine cuts out, as in revs drop to zero.. lift my foot and she's fine again.
Any suggestions on what to look for?
It drives fine if I'm gentle on the accelerator and I can't replicate it when in neutral and revving.
Hi,
It would be worth checking that all of the pipes around the inlet manifold have been fitted correctly and that any plugs that may have been knocked etc.
Sometimes the main intake pipe gets brittle and can split when its been disturbed.
