Could simply be the oil is a bit on the cold side and thick. Not sure if the d4d has hydraulic tappers but these can do this. Also any engine when cold is going to complain a bit. Without hearing it, it's hard to tell but I would expect it to be normal and go away when the weather warms up. It doesn't hurt to run it and get a bit of heat through before setting off on really cold mornings. 80k, that's just run in so you shouldn't have anything to worry about. Do your usual checks of engine and trans oil and if low top up.
I'd be interested to hear from others on this but I would say it's normal though I have no experience of that engine.
Thanks for that , always changed oil on time and used genuine filter, I would also like to hear from others.Could simply be the oil is a bit on the cold side and thick. Not sure if the d4d has hydraulic tappers but these can do this. Also any engine when cold is going to complain a bit. Without hearing it, it's hard to tell but I would expect it to be normal and go away when the weather warms up. It doesn't hurt to run it and get a bit of heat through before setting off on really cold mornings. 80k, that's just run in so you shouldn't have anything to worry about. Do your usual checks of engine and trans oil and if low top up.
I use Doxos 2 which is 5W/30 fully synthetic.If its of any comfort, my old 80 (410k km) sounds like a can of dried peas on first start up when very cold, but it calms down a bit when the oil gets pumped up to the cam.
If it doesn’t tick or tap when warm, it sounds like tappet adjustment (if there is such a thing on a D4d) is OK.
Of course as @StarCruiser commented, its hard to say without hearing it first hand (or should that be ear?)...
By chance, do you use the recommended oil viscosity? It’s 10/40W in my 80, but I don’t know what’s recommended for the D4d.
Is that something that's possible to interrogate with the right diagnostic tool Phil?At 80,000 klms I would be getting the injectors checked. It is a sign that there could be a leakage past the injectors and is most prevalent when the engine is cold. The engine is still quite young and although the 120 is an older version now it should be reasonably quiet.
Thanks Flint I will have a look.Techstream is Toyota diagnostic software, a handy tool. It comes with a gubbins that plugs into the diagnostic socket below the dash on the drivers side (on UK models). Something like this:
https://www.ebay.com.au/itm/MINI-VC...223697256?epid=2064610302&hash=item2a6d60f568
No problem. Rob Cowell is the man who knows more about this than I do. I think that he posted pics of Techstream in action, showing the relative values of injectors etc..
