MetalDonkey
- Jul 24, 2017
During the winter snow , I decided, as you do to play on the slippery surfaces with my 4x4.
I could not get the vehicle into low ratio, no matter how hard I pulled the lever ,all I got was a graunching of gears . I could not get it into neutral . The lever is stuck in High Ratio. My local mechanic tells me that I will have to drop the gearbox for investigation and that will be 8 hours labour , Has anyone ever experienced this type of fault, I am hoping its just a linkage and not a reconditioned gearbox. Any know a good mechanic in London or the south that has the knowledge on LandCruisers..
