Fault code 97
Rick Jacobson
australia
Hi I have a HDJ 79 Landcruiser with the 1HDFTE engine in it . Have a problem with the engine stopping when I'm driving it . Fault code 97 is coming up ( spill control valve circuit). Have replaced spill control valve driver box due to it becoming hot & smell of burning plastic. This didn't work so had injection pump replaced still no good. Replaced ECU as there was no signal going/ coming back from ECU to EDU. This was confirmed by Toyota dealer workshop. The problem is still there. Has anybody had the same problem?
Hey mate what ended up being the fault i have this exact problem at the moment. the car just randomly goes into limp mode and then stalls out
G'day would you be able to tell me what ended up being the problem
