Fault Code Reader?
Wildplaces
europe
Hi all
Following up on a previous post, how do I read the fault codes from my 2005 prado?
I don't have a gizmo for this, so what's recommended (keep it inexpensive please)
I'm in the UK so prefer to buy from a UK supplier :)
Charles
Three options that have worked for me:
1. Toyota Techstream - you put this on your computer and buy a cable off ebay. This is probably the cheapest and most flexible way to get all the data from all the onboard systems. You can also program keys, injector compensation codes etc if you ever need to. You might need a bit of computer savvy to get it setup and working right.
2. Denso Intelligent Tester2 (IT2). A self contained unit that pretty much does what techstream does, Expensive and probably not worth it IMHO!
3. Autel MaxiDiag MD 805. I got this to scan by LC before I bought it and it did a good job and can read all the systems. Don't know if they're still available, but there's probably an equivalent. Think it was about £150
There are probably other options that will work, but beware that generic OBD2 readers tend not to work on these 120's - especially the older ones. I've had no success on my UK 2006 model with bluetooth dongles - I've tried MotoDia ELM327 and an Autophix 3210. Theres videos on YouTube of the Autophix working with other 120's though.
If you search on here there's other info about this!
That's really helpful - thanks.
I've had a look at a few cables on Amazon for £25-35 and they pretty much all say up to Windows 7. I have Windows 10, so not sure what to do on that one.
Also, is there an option to plug something in which will talk bluetooth to my phone for readings on the go?
Told you I was new to this :)
Does the software itself cost anything?
I've dedicated a windows 7 box to Techstream (just a cheap toughbook for £100 odd) so I've only tried it on windows 7. I think others have got it working on windows 10, but you'll have to search around for the details.
I've had no luck with bluetooth adapters, but I think they do work on some cars. Theres a guy in OZ who has an autophix working, but it didn't work for me. I wanted to use one to try and get some details up on a android headunit, but it wasn't to be. Have a look at this youtube:
I think the older cars, and the UK cars in particular are a bit more fussy in what they will talk to!
Don't worry mate, we're all learning :) The software came with the cable for me on ebay, and was about £20 or so. Not sure what the official position is or if it was even the latest version of the software - but then the 120 isn't new either, so it was plenty good enough!
I use techstream and for the cable and software from ebay with it running on a win10 laptop. It's a bit tricky to get it working, but there is a thread on here with some useful links.
Hi, use icarsoft pro, did by it from a dealer in Norway(iCarsoft CR PRO Diagnostic Tool: The OFFICIAL iCarsoft UK Outlet - [Leaving Land Cruiser Club])
Frame 20/20:
Calculate Load ----- 20%
Coolant Temperature ----- 82°C
Map ----- 96kPa
Engine Speed ----- 699rpm
Vehicle Speed ----- 0mph
Intake Air ----- 10°C
MAF ----- 6.57gm/s
Engine Run Time ----- 1702s
MIL ON Run Distance ----- 0km
Fuel press ----- 33030kPa
Target EGR Position ----- 61.57%
Warm Up Cycle Cleared DTC ----- 12
Distance From DTC Cleared ----- 643km
Atmosphere Pressure ----- 99kPa
Battery Voltage ----- 11.95V
Accelerator Sensor Number 1 Volt ----- 16.08%
Accelerator Sensor Number 2 Volt ----- 31.76%
Running Time From MIL ON ----- 0min
Time After DTC Cleared ----- 1122min
Pilot 1 Injection Period ----- 428us
Pilot 2 Injection Period ----- 453us
Main Injection Period ----- 716us
After Injection Period ----- 0us
Pilot 1 Injection Timing ----- -17.50°CA
Pilot 2 Injection Timing ----- -11.30°CA
Main Injection Timing ----- 3°CA
After Injection Timing ----- 0°CA
Injection Feedback Learning ----- -0.01mm³/st
Injection Feedback Val 1 ----- -0.47mm³/st
Injection Feedback Val 2 ----- -0.63mm³/st
Injection Feedback Val 3 ----- -0.31mm³/st
Injection Feedback Val 4 ----- 0.94mm³/st
Injection Volume ----- 8.87mm³/st
Received MIL From ECT ----- OFF
Shift Position Sig From ECT ----- 1st
A/T Oil Temperature From ECT ----- 46.87°C
SPD(NO) ----- 0rpm
SPD(NT) ----- 650rpm
ECT Lock Up ----- OFF
Fuel Temperature ----- 34°C
Accelerator Position ----- 0%
Throttle Step Position ----- 181Step
VN Turbo Command ----- 90%
Target Pump SCV Current ----- 1243.44mA
Inj. FB Vol. For Idle ----- -1.99mm³/st
Alterate Duty Ration ----- 100%
Target Common Rail Pressure ----- 35000kPa
EGR Close Learn Value ----- 0.94V
Codes(Include History) ----- 0
Starter Signal ----- OFF
A/C Signal ----- OFF
Neutral Position Switch Signal ----- ON
Stop Light Switch ----- OFF
Power Steering Signal Record ----- OFF
EGR Close Learning Status ----- OK
Diesel Throttle Learn Status ----- OK
Throttle Open Switch ----- OFF
EGR Lift Sensor Output ----- 58.98%
EGR Close Learning Value ----- 0.95V
EGR VSV ----- OFF
ACT VSV ----- OFF
ACM INHIBIT ----- ON
TC AND TE1 ----- OFF
Initial Engine Coolant Temperature ----- 50°C
Initial Intake Air Temperature ----- 33.75°C
Intake Air Temperature (Turbo) ----- 25°C
Common Rail Pres Sens2 ----- 30180kPa
VN Turbo Type ----- COMMO
VNT Maximum Angle ----- 99.60%
VNT Minimal Angle ----- 39.84%
Injection Pressure Correction ----- -8.07mm³/st
Accelerator Sensor Out Number 1 ----- 0.80V
Accelerator Sensor Out Number 2 ----- 1.58V
Check Mode ----- OFF
SPD Test Result ----- Compl
MIL ----- OFF
Number Of Emission DTC ----- 0
OBD Requirements ----- NO
Model Code ----- KDJ12##
Engine Type ----- 1KDFTV
Cylinder Number ----- 4
Transmission Type ----- ECT 5th
Destination ----- W
Model Year ----- 2004
System Identification ----- Diesel
