1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Filter light
Martin8 Feb 26, 2011
  1. Martin8
    Martin8 New Member
    4
    0
    1
    Does anyone know what the yellow filter light means on the dashboard?
    It comes on when starting, and sometimes stays on for a little while.
    Thanks,
    Martin.
  2. Rob
    Rob Well-Known Member
    3,013
    6
    38
    Garage:
    Map
    Could that be a water in the fuel filter warning light by any chance?
  3. Olazz
    Olazz Well-Known Member I am in zimbabwe
    1,124
    21
    38
    Map
    Yes its the water in the fuel light.
    My Africa spec 60 has done it since new. As long as the light goes out no problem.
  4. Martin8
    Martin8 New Member
    4
    0
    1
    Do you mean there is water in my fuel filter????
    Is that condense water?
  5. TITO
    TITO Active Member
    51
    0
    16
    Map
    He few that the decanter under the chassis is full too of water.
    It is necessary to purge it by saw her of bottom
  6. Rob
    3,013
    6
    38
    Garage:
    Map
    one of the jobs of a diesel fuel filter is to catch water. When it fills up you can usually drain it, there is usually a small tap on the bottom of the filter assembly. Not sure what its like on the 60. If that doesn't work you need to replace it. You may also find that the sensor could be faulty.
  7. TITO
    TITO Active Member
    51
    0
    16
    Map
    Purge the decanter, changes filter with diesel oil.
    Should be that good.
    :thumbup:
Share This Page
