thanks for the info! i did end up buying the '82 fj60 last night. I guess over the years it has a few conversions because now it is running a diesel with a turbo. Not sure if it is a 12ht or not..........is there a way to find out, i dont see any tags on the engine block.
Also it has a 5 speed........it has a bull gear low and then 4 more gears........again not sure how to find out what transmission it currently is. Hoping its a h55, lol.
Any advise to point me in the right way would be awesome!
Thanks guys
First step in identifying your engine is to count the number of cylinders then read this
quick rundown of the various engines that are installed in Landcriusers:
3B: 4 cylinder naturally aspirated; available in the Canadian market in BJ42, BJ60, and BJ70 as well as other markets. This engine takes very well to an aftermarket turbo.
13BT: turbo’d version of the 3B.
1PZ: 5 cylinder, naturally aspirated (very similar to the 1HZ; except missing one cylinder). Very limited production run from 1990-1995
2H: 6 cylinder, naturally aspirated.; available in the Canadian market HJ60 as well as other markets. Does not turbo well; low boost only.
12HT: turbo’d version of the 2H. Excellent engine and quite powerful. Very limited production run 1985-1989
1HZ: 6 cylinder, naturally aspirated. Excellent engine and is seen as Toyota’s 3rd world workhorse engine. Production run: 1990-current This engine takes very well to an aftermarket turbo.
1HDT: turbo’d version of the 1HZ. Excellent engine for a 80 series conversion. Available from 1990-1995
1HD-FT: 24 valve version of the 1HDT. Excellent engine for a 80 series conversion. Available from 1995-1997
1HD-FTE: computer controlled version Toyota’s 6 cylinder diesel. Started in 1998.
1VD-FTE: Toyota’s first common-rail V8 diesel also debuts a new twin-turbo system that delivers strong power while reducing fuel consumption as well as emissions.
