I just got it back from the electician's today. I need to find a replacement clock and a new cigarette lighter (already ordered one from eBay). The LC clocks I found were similar to mine, but on the back they were marked as 12V not 24V Any suggestions?
Do you have 2 batteries? If not then you don't have anything on the car that will run on 24 volts. If you do then its highly unlikely that you have 24 volt electrics other than possibly the starter (on some LCs the batteries are in parallel not in series). Easy way to find out is to use a multimeter where the clock and lighter connects.
Hmm my 2c - I think it could be 24V throughout. Some of the 60 series have 24V electrics. Stands to reason that a 70 from the same era could have the same
Just got it back from the uphosterer... I did the overhead upholstery. As soon as I get hold of the inner door-handles (which are still missing), I will take it back to start the main upholstery...
I'm missing my Cruiser right now...had a problem with the wheel-hub and I have to wait for about 3 weeks for the parts to arrive, so it's stuck at the mechanic's...
Just brought my baby from a general service...now I'm preparing to change the second front wheel disc and fit new brake pads....after that...I will be restarting to restore the interior or fixing the front panel...
Something I forgot to mention....managed to fix the original clock! In a couple of weeks I am to take it to the panel-beater to replace the front panel and to fix a dent I have on the driver's door...
