Oli.g
- Aug 31, 2019
Hi everyone, my front driverside lowerball joint and wheel bearing went and noticed i had a leak from the diff seal, ive also had slight leaks on the transfer case and near side rear axle seals which have gotten quite bad
Im going to try fit them myself, front and rear axles i can strip without a problem but the transfer case i was worried about, the prop comes off and leaves the flange, how do i remove the big nut om the flange or do i leave it in gear an itll jam so it doesnt spin?
Also when fitting the seals am i best off buying a seal driver kit? Any tips or help would be appreciated and sorry if these are dumb questions ive not done much mechanical bits myself haha
