Rob Cowell
- Nov 15, 2011
Not sure where best to put this, but I'll try here.
So I've bought a Pendle bike rack to get a couple of bikes to France. Seems a decent thing.
Having put it on I had a look underneath. I look underneath a lot. And it looks like the tow bracket is moving on the chassis. This is not good. The underside is pretty rusty so fearing the worse I took the bumper off to get a better look at the cross member.
Mud.
More mud.
But it once jet washed the cross member looks in decent condition. Albeit full of mud!
So if I lean across the rack, which is acting like a lever, and I'm not little I can feel flex here.
Thats the tow bracket where it's folded and sits under the crossmember and bolts on. I tried to video it but you can't see the movement with the whole chassis moving. You can see it by eye though.
This is the construction from the side.
The tow bar is two bits of 6mm plate. One at the back that turns 90 degrees and bolts under the chassis. You can't quite see the bend here, there's a thin plate obscuring it. The plate infront has the ball mounted on it. It bolts to the back plate.
All the bolts are tight. It can only be the bracket itself flexing. Does this sound normal / OK? I've never looked in detail at the bracket with something swinging off it. I tow 2.8 tons quite a lot. It could have been doing this since day 1. Or someone might tell me they notice theirs doing this the day before their cattle trailer overtook them on the M4.
Mud.
More mud.
