AndyCook
SOLD ************* - Toyota Land Cruiser Colorado 3.0 TD FX (95-series)
My Colorado is for sale, since I am replacing it with a newer Hilux
Its been a great vehicle on road, in snow, on greenlanes and trans-European trips
Diesel - Automatic
Registered 2000,
7-seats
115,000 miles
VED expires 31/3/14
MOT expires 21/4/14
£3495
Centre and Rear Difflock's working, and low-range
2 sets of keys
Unlike many FX spec Colorado's this one has alloy wheels and aircon
Modifications:
Front Warn winch on in-bumper TBR winch mount
Winch control switch on dashboard
Winch isolator switch in front grille
Safari snorkel
OME 40mm heavy duty suspension lift kit - coil springs and shock absorbers
40mm extended antiroll bar links to complement suspension lift
General grabber all terrain tyres 225/75-16
Tow bar and 7-pin electric socket
Spot-lights on bumper (operate with full-beam)
Front and rear differential, transfer box and gearbox extended and raised “breathers”
Fold down table on inside of boot door
2 front and 2 rear chassis mounted Warn recovery hooks
New Toyota Rear differential lock actuator fitted in 2012
No service history book when purchased in 2009 / 74,000 miles.
But I have some service receipts from previous owner
I have serviced it since 74k miles in 2009 according to the schedule, oil and Toyota oil filter change every 6 months or 4500miles whichever sooner.
I have kept my own service record book since 2009 and have kept receipts for service items and spare parts.
Air and Fuel filter replaced each year.
Coolant, Transmission Fluid, Front and Rear differential oil and transfer box oil replaced regularly as specified in service schedule.
Chassis and underbody treated with dinitrol in 2012 (most of orange stuff you can see in photos on chassis is sand/dust from Morocco)
Radiator replaced in 2009
Air-conditioning works well – new Toyota condenser (radiator) fitted summer 2012 by a specialist and system recharged and tested.
Vehicle given pre-MOT style inspection by Alexander Wallace Toyota in Elgin in August 2013, including them replacing some parts (exhaust gasket and clamp, both front lower control arm ball-joints, anti-roll bar bushes, rear brake slider pins and rubber boots)
Body work got scratches from bushes
Interior trim has some holes where I had switches and wiring which have since been removed.
Scuffs on interior boot trim from luggage and a crack in plastic
Occasional slight clunk noise from back of vehicle when going over potholes, due to boot door knocking on a stop since the rear door hinge being worn, I replaced the lower one with a bolt and that helped reduce it a lot.
O/S rear of sill has some bubbling paint (see photo)
chassis repaired with 2 welded plates by a garage in 2011 - at rear, near lower control arm mounts
slight weep of oil at join between gearbox and transfer box.
URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5810%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5811%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5812%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5813%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5814%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5816%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5817%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5808%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5807%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5806%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5805%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5804%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5803%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5802%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5801%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5799%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5798%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5797%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5796%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5795%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5794%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5793%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5792%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5791%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5790%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5789%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5788%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5787%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5785%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5784%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5783%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5782%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5779%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5778%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5777%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5776%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5775%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5774%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5773%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5772%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5771%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5769%20%28Medium%29.JPG"]URL]
[URL="http://www.bridgefootcottage.co.uk/temp/Wugg/IMG_5768%20%28Medium%29.JPG"]URL]
Service History since 2009
Genuine Toyota filters used
1[SUP]st[/SUP] May 2009 74221 miles
Oil and Oil Filter
Air Filter
Fuel Filter
Rear Diff oil
Front diff oil
Transfer box oil
New roughtrax radiator and Toyota red coolant
ATF drained/replaced with 5 litres
New thermostat
New exhaust main silencer box (milners)
9 May 2009, 74,300 miles
4 litres ATF drained and replaced
Greased prop-shaft UJ’s
30 May 2009 – 74,684 miles
Replaced Timing Belt, idler pully and tensioner
Renewed viscous fan clutch fluid – 2000cst
14 Nov 2009 – 78924 miles
Oil and oil filter service
Rear diff pinon flange seal replaced & diff oil
Rear shocks replaced with OME nitrocharger 40mm lift shocks
22/5/10
Replaced front and rear coil springs with OME 40mm lift springs
Front shocks replaced with OME shocks
23/5/10 – 84,440 miles
19/11/10
Replaced leaking transfer box oil seal (front) and replaced transfer box oil
6/12/10 – 87, 338miles
Air and fuel filters replaced
8/12/10 – 87, 437 miles
29/4/11 – 89, 996 miles
Replaced coolant with Toyota red coolant
Refilled viscous fan clutch fluid with 7000cst
New rear brake discs and pads (EBC)
3/6/11 – 91, 678 miles
Replaced front brake pads and discs (EBC)
8/10/11 – 95,622 miles
Air filter replaced
23/12/11 – 98,258miles
Replaced fuel filter
5/3/12 – 99, 578 miles
10/3/12
Replaced main silencer exhaust box (Roughtrax part)
April 2012
Replaced rear trail pipe exhaust section (Milners part)
31/3/12 – 99,984miles
Replaced steering rack bushes (super-pro)
Replaced front differential, OS oil seal (Toyota part)
Replaced front diff oil
Replaced front flexible brake hoses (Milners part)
Drain and refill 4 litres ATF
17/7/12 – 104, 691 miles
Air filter changed
New gearbox sump fitted (Toyota part) – flushed 15 litres ATF
OS front wheel bearing replaced = KOYO – same as Toyota part, oil seals replaced (inner oil seal and dust seal = Toyota parts, outer seal = milners)
New air-con condenser radiator – Toyota part, fitted and re-gassed by specialist
November 2012
Fitted new front OME 881 coil springs (old one snapped)
30/12/12 – 106, 178 miles
16/2/13 – 106,331 miles
May 2013
Greased all prop-shaft UJ’s
New front antiroll bar-link arm bushes and washers (Toyota)
New front NS antiroll bar stirrup bush
19/5/13 – 107, 784 miles
Drained and refilled coolant with Toyota red
Replaced bottom radiator hose
20/5/13 – 107, 793 miles
Replaced front and rear diff oil
Replaced transfer box oil
25/5/13 – 107,881 miles
Replaced rear propshaft, rear UJ with Toyota part
Replaced transfer box, rear oil seal and companion flange seal and new nut (Toyota parts)
107, 876 miles
Fitted new OS front CV joint
Fitted new OS Anti-roll bar link arm (Milners)
26/7/13 – 110,464
Replaced front brake pads (EBC)
Replaced rear axle upper control arms/bushes – Toyota parts
22/8/13 – 110,505
Alexander Wallace - Toyota Elgin Garage – vehicle inspection and parts replaced:
Front and rear anti-roll bar bushes
Exhaust centre box gasket and clamp: springs and bolts
Replaced rear brake pads (EBC)
Replaced rear brake sliding pins and rubber covers
Checked glowplug operation – OK
Checked emissions – OK
Replaced bottom steering knuckle lower ball-joints – both sides
4/9/13 – 110,515 miles
Replaced front NS wheel bearing, snap rings, 3x oil/dust seals – all genuine Toyota parts
Replaced alternator – milners part
26/10/13 – 114,841
Replaced rear lower control arm and panard arm bushes – superpro
Replaced rear anti-roll bar link arm bushes and washers – Toyota parts
Diesel - Automatic
Registered 2000,
7-seats
115,000 miles
VED expires 31/3/14
MOT expires 21/4/14
£3495
2 sets of keys
Modifications:
Safari snorkel
URL]
Oil and Oil Filter
Air Filter
Fuel Filter
Rear Diff oil
Front diff oil
Transfer box oil
New thermostat
22/5/10
19/11/10
Air filter replaced
10/3/12
April 2012
Air filter changed
November 2012
May 2013
107, 876 miles
26/7/13 – 110,464
22/8/13 – 110,505
26/10/13 – 114,841
