Front towing line crane remote controller
Kyle64
Hello gentlemen,
I have a 1993 land cruiser 80 series (XW80) as in the link
https://www.beforward.jp/toyota/land-cruiser/bg165736/id/1229713/
Exact red lines, gray color, very similar except mine has a crane at the middle of front bumper. Brand is Seiko, can tow up to 4,000 pounds. When I bought it 2nd hand, seller said he lost the remote controller to it.
Crane and its remote controller from the manual are attached
I appreciate very much if someone has info about the resourse I can find remote controller from. I asked to many toyota dealers, but no help
Welcome Kyle.
Getting hold of a genuine winch control without a winch attached is a big ask. Also the after market winches have different numbers of pins at the plug end. My Aisin winch ( behind the bumper fitting) has 4 pins but others I've seen have 5.
Hi Kyle, where are you located? This would be something that could be replicated by testing the contacts though finding a plug may prove difficult. You could try on Amayama but you may be searching for hens teeth.
Certainly just fitting a remote would work easily, but I'd suggest that if this was the ONLY method of spooling the winch, then I'd fit a high quality remote. I'd recommend the Mini Lodar. More money but pretty much guaranteed to work forever and most certainly when you need it to.
Personally, I'd fit a wired remote connector and a remote receiver, that way you have a backup for wired if things go wrong. If you can get the original wiring diagram then it would be easier enough to reverse engineering
