- May 26, 2014
anyone got the brake circuit diagram for non ABS with rear discs please?
not sure if it even exists..Which diagram are you looking for exactly?
I would say due to the fact the LSPV is allowing the pressure to alter in the rear lines it's a front rear split , diagonal wouldn't make sense ....not sure if it even exists..
all of my FSMs etc are on my old laptop which is virtually unusable. need to get all that stuff swapped over.
what i really need to know is the circuit split diagonal or front/rear. im thinking maybe front/rear as two lines go into the LSPV then one comes out and Tees off to the calipers.
this was my presumption also, though i constantly remind myself not to presume...I would say due to the fact the LSPV is allowing the pressure to alter in the rear lines it's a front rear split , diagonal wouldn't make sense ....
normally diagonal split is on dual circuit systems to retain braking if one system is compromised
I have a feeling I'm teaching Granny to suck eggs so to speak but that's how I figure it would work....for what it's worth .
