SimonD
- Mar 15, 2010
Anybody come across Econokits before? http://www.econokit.fr/index.php/en_US/revolution-technologique.html. There is a UK distributor http://fuelenhanceruk.webs.com/ . Looks like french technology. I've pasted some of the website here [more on the links]:
The functioning of the Econokit
For years, we have known the efficiency of water injection in heat engines. By injecting water, the output increases. Many engines have functioned with the injection of water (in particular mixed with ethanol, e.g. Douglas DC 6 planes, or Corsair planes and still today Canadair firefighting aircrafts). In the renowned French scientific review “Les Techniques de l’Ingenieur”, you can read “injecting water into the air taken to the engine enables the reduction of the combustion temperature and reduces the oxygen concentration by diluting with steam.
Ideally, one obtains humid air, partially modified by the reactor-convector. The idea is to prevent the engine from taking in ‘dry’ air by adding air which has previously gone through a water-reservoir (which makes bubbles) to be humidified while bubbles are formed. The bubble process is the means which has given the best results.
The obtained gas still contains liquid water in droplet form at its arrival in the engine. Its revaporization, very endothermic, lowers combustion temperature, catalyzed by the water itself. This phenomenon also acts on the length of combustion time and allows pressure to be better utilized in the cylinders, improving notably the power potential at low rev.
Engines work better in rainy conditions and ideally when there is fog.
Heat engines burn fuel with air’s oxygen. If combustion was perfect, heat engines would only reject water (H2O) and Carbon Dioxide (Co2).
Below is an example of a chemical reaction for diesel engines:
2 C16H34 + 49 02 -> 32 Co2 + 34 H2O (30g air / 1g fuel)
Unfortunately, combustion is often imperfect and produces the following products:
Unburnt hydrocarbons
Nitrogen Oxide (NOx = NO and NO2)
Carbon monoxide CO
Oxygen
Nitrogen oxide comes from the oxidation of the nitrogen in air during combustion. It is toxic and irritant. Carbon dioxide, which everyone is looking to decrease, because of the greenhouse effect, is directly linked to the quantity of fuel consumed. It is easy to understand, both advantages of the Econokit which are brought about the expected reduction of fuel consumption: the financial savings and the reduction of Co2 emissions.
Carbon monoxide CO
Oxygen
