Fuel filters and rubber strap things....
<Now I have my cheap rubber strap things from the DIY shop I'll try them
first, if no joy I'll remove the whole lump. In fact if I can loosen the
filter first I'll probably remove the mount anyway as it'll make messing
with the sensor easier.
Ian.>
The other use of the rubber strap things is for wrapping around your arm to
check your blood pressure when it's not going well....Any other uses for
rubber strap things should probably be sent off list I think or Julian will
wield his moderators bat.....:)
Neill
