cjb80
- Mar 15, 2021
So my next job is to get the fuel filler flap to open, using the pull on the dash.
The previous owner attached a wire, that can be pulled when you open the back door..
Going in behind the housing in the rear, I can see the cable is attached... However the mechanism itself is loose and can rotate.. I assume it should be fixed, so there's no movement which will allow the release cable to operate correctly? But I can't see where the fixings should be ???
