The latest annoyance my truck has presented (since the oil gauge locked itself at appx. 0lb) is the fuel gauge, which for 10 years or so since getting the truck has worked, to its own measures admittedly, rushing down to 1/2 when it's still 3/4 then crawling the rest, but it worked and the warning light used to come on with about 25km to go (don't ask how I know ) which was very useful.
Now it reads 1/2, whether full, empty or anywhere in between.
OK, I know I have to start trouble-shooting by checking the resistance in the tank sender then working my way forwards to the panel gauge indicator, but has anyone else had this problem?
As it's likely to be the tank sender (moving parts wearing out is assumed) are these still available from Mr T? Should I go OEM (if yes) or will an aftermarket unit be available and worth getting?
Lots of questions, sorry. But I'm trying not to re-invent the wheel here, if someone's had the same experiences.
Not happy, it's a PITA not having a fuel gauge.
