- Mar 1, 2010
You probably have to prime by pushing the plunger up and down on the filter housing until it becomes stiffer.
It was easier to let the walbro pump do it for meYou probably have to prime by pushing the plunger up and down on the filter housing until it becomes stiffer.
Dave in Spain said something about a spring in the pump could be broken if it does that....Dave2000?When I pull onto the drive facing uphill, probably around 1 in 10-12 slope, the idle speed drops noticeably. Also, when starting, it doesn't fire instantly as normal but spins over a few revs, unless I touch the throttle slightly. None of this happens when facing downhill. I've never noticed any power loss on the move though and EGT's can still max out under heavy load so I don't think there's any restriction in fuel delivery as such.
This can be a sign the diaphragm in the hand primer is showing early signs of failing.When I pull onto the drive facing uphill, probably around 1 in 10-12 slope, the idle speed drops noticeably. Also, when starting, it doesn't fire instantly as normal but spins over a few revs, unless I touch the throttle slightly. None of this happens when facing downhill. I've never noticed any power loss on the move though and EGT's can still max out under heavy load so I don't think there's any restriction in fuel delivery as such.
If a pump is fitted to overcome a pinhole or leak in the supply side presumably a diesel leak will occur at that point?
My idle speed on the flat is around 600-650rpm rising to around 800 when the AC kicks in or when turning and activating the PS idle up mechanism. I could probably set the idle up a tad lower but, mine being a manual, the varying idle speed due to AC And PS isn't really a problem TBH. In fact, the idle drop when facing up hill isn't really a problem in itself, more an observation. It's certainly not bad enough to warrant the time, effort and £££ of a pump removal and rebuild!
