Bungarra
- Nov 4, 2012
1HZJ79R 2006 non turbo
Went over a cattle grid, (not hard in second gear) leaving the station when the engine just took off, full revs!
Turned the key off, it came down a bit but had to stall it to stop.
Been using drum fuel and had some water problems in the filters of late.
I changed out the fuel filters, primary had a bit of water as did secondary with a bit of white gunk.
Started her and full noise again, I thought these fuel pumps had a rack like of old, so gave it a few whacks hoping it would free the throttle inside, but no.
But I am told since, the pump doesn't have a rack.
I have had a truck go full noise through oil inhalation (making its own fuel) this is not the case here.
But this has me stumped.... I don't see any other alternative but to replace the fuel pump.
Any suggestions?
Any suggestions?
