Something that I've been toying with for a long time now is up-rating my 'B' spec (+25%load) Ironman rear springs to 'C' spec (+30%load) ones
While I had all of my shelving unit and off-road paraphernalia out of the vehicle in pursuit of the illusive off-side reversing light wiring viewtopic.php?f=14&t=13340 I had a chance to take a reference point measurement from the ground to the vehicle. Then once it was all loaded back in I took a second measurement. She'd dropped 17mm!!!! When you consider this is just the shelving unit and what I carry day to day in the back of the truck before I chuck in all of my camping gear, stoves, food, spares, Hi-Lift etc for a weekend away it seems a lot of clearance to sacrifice to me. The total weight of what I put back in came to just under 80Kg (I weighed it all as I put it all back in last night, the shelving unit is about 30Kg). There must be another 80/100Kg of other kit when she's loaded for a weekend away on top of this 80Kg!
It's not so much that she dosn't handle well even with all of the additional kit in. I've been to Wales, Shropshire, Lincomb and much local laning without to many problems. It's more to do with the way that she sits, with nowt in she sits as I'd like to see her sit with the 80Kgs of my everyday gear in the back (back end slightly higher than the front end), not a lot just enough to look right. Becoming more level with the extra load in. At present she ends up with her back end lower than the front end when fully loaded for a weekend away Not sure how the new springs will work out Got plenty of time to ponder though as I spoke to Paul today from WestCoast and he want have any 'C' spec rear springs in untill March So popped my name down for a pair as soon as they land
I'll let you know how I get on with them once they're fitted
