Hi Graham
The only way to remove a fault from the ECU memory if you cant erase it by
diagnostics is to disconnect battery/batteries for at least overnight. Then
if the light still comes on the fault is still current - This worked on acustomers Amazon.
___________________________________________________________
Tiscali Broadband from 14.99 with free setup!
http://www.tiscali.co.uk/products/broadband/
