Until this great build i always believed any petrol 4x4 mpg would be prohibitive (never giving up on the 1hz search) You got me researching the 1GR-FE engine.
It s quite clear you know what you re doing. What's your take then on the reliability section near the bottom of it page?
(I pasted it here)
"The reliability of the 1GR-FE is not the best side of that engine and not suitable especially for a work truck or a big family SUV. The engine block of the 1GR-FE has cast-in special thin cylinder liners. Their thin walls make it impossible to bore the block and rebuild an engine with a damaged cylinder wall surface. The common failure for a relatively big mileage 1GR engines (near 150,000 miles) is a blown off head gasket. The water pump is a weak point; its longevity is about 40-50k miles. So, pay extra attention to the condition of the coolant system. The dual VVT-i 1GR engine is smoother and quieter than first 1GR-FE engines. Also, the simple VVT-i engines had non-stop problems with ignition coils.
Like a modern engine, the 1GR requires a proper maintenance, high-quality fuel, and engine oil. The engine longevity is over 200,000 miles. After that line, most of the 1GR engines need a new cylinder block.
Loving the build process - keep it coming!
1GR-FE 4.0 V6 Engine - In-Depth Look at Design and Reliability
What is the 1GR-FE 4.0 V6 Engine ? Is it good or bad? Read about Toyota 1GR-FE 4.0 V6 Engine design and features, its the most common problems and relaibility.
www.motorreviewer.com
(I pasted it here)
