Hi Kirk,
The best solution is to clean the rubber window surrounds thoroughly to
remove all the dirt and then lubricate with a silicone/ptfe based
spray.
They are best pulled out completely - lower the window and prise them
out from the top initially.
The next option if you are up to it is to strip the main switch in the
drivers door and clean off the contacts - these can get gummed up
reducing the power going to the windows.
If you are still having problems after that then you may need to
consider replacing the motors.
Julian Voelcker
07971 540 362
Skype: julianvoelcker
Cirencester, United Kingdom
1994 HDJ80, 2.5" OME Lift
spray.
Julian Voelcker
07971 540 362
