Heater problem on HDJ80 => Solved!!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Hi HEBERT,
Not the temperature setting lever?
No, but will chase up - should be something either this month or next.
Julian Voelcker
Mobile: 07971 540362
Cirencester, United Kingdom
1994 HDJ80, 2.5" OME Lift
Morning all,
can someone elaborate please, what is this mysterious little lever and exactly where is it ?
I can't say that I have ever spotted it or read of it in the owner's handbook. How sad is that, I read my handbook !
Thanks, Gareth '97 1-HDFT
Hi Guys
Yea Ill second that where is this magical lever to solve all my heating
issues.
John C
92HDJ 80 1HDT Rep of Ireland
SNIP
Hi Gareth,
I was joking - I was wondering if Lio was referring to the temperature
adjustment level which is part of the climate control system - move it
one way to increase the temp and the other way to lower it ;-)
The temperature for the rear heater isn't controllable so will always
blow hot unless you have an 80 kitted out with the dual zone climate
control system so that you can adjust temps independently front and
back.
Julian Voelcker
Julian, you rascal - you were joking and I fell for it !!
Gareth.
Hold on guys, am I to be kept in the (cold) on this. where, what are you
talking about, is there no magic lever to heat my poor body first thing in
the cold mornings. Ah just when I thougt all my dreams came true regarding
my retarting heating.
John C
