Iwan
- Mar 28, 2011
Standard front brake caliper as stock but with seized pistons!
The larger 2005 Hilux Kdn front calipers have a greater pad surface area and also have twin 50mm pistons as the 60 series has 1x50mm and 1x40mm. All in all a greater front end braking setup.
Fitting is basically a straight bolt on as both have 88mm fixing centres and the same disc diameter. But adjustments are needed to the disc guard, easy!
Just thought I let you all know of this mod as I had been driving on 25 year old system and feels better having 8 year old parts!
