Hi Guys
New member here and first time posting, I have a 1988 HJ75 Landcruiser that I have bought with a secondary fuel tank... However it is not connected in any way shape or form. So im wanting to know how other have wired/plumed up the secondary tank.
Have you got it so as it pumps fuel into the main tank or is there a change over switch and a second fuel line installed to the injectors?
If it is set up to feed the main tank how do you control the pump so as when the tank is empty it doesn't continue to run?
Any help, tips or trick are greatly appreciated
Thanks
Jayden
Thanks
Jayden
