Every time i went to fill up with diesel i got this hissing sound as i unscrewed the fuel cap as air rushed into the filler pipe. I have been told by Julian at Overland Cruisers that my fuel tank breather is blocked and that it is in the fuel cap. As i have fuel starvation issues i decided to get it sorted and write a guide as i could not find one anywhere.
First remove the inner threaded part from the handle by holding the handle firmly in one hand and gently pulling them apart at an angle
This is a picture of the filter element, i took all these photos after i cleaned it as i thought it was solid plastic there due to all the dirt on it
you can remove it with a tiny flat head screwdriver or with a sharp knife
also pry out this bit of plastic on the other side, just be careful as there is a loaded spring underneath, take note which way round the valve is under the spring.
Now clean all the parts. i have laid out all the parts below in the correct order of assembly
to assemble follow the steps in reverse
when assembling check if the valve is not stuck by inserting a small screwdriver as below
