[Hub cap for Front Passenger wheel]
Hi Renate,
If, as I suspect, you're missing the small rounded metal cap that knocks on
to the hub itself and keeps the grease around your cv splines from coming
out you need part number 43423 35010. Should be less than a fiver.
The number the Toyota guy has given you is for the wheel embellisher that
clips to the wheel and hides the hub from view - I think its plastic and has
'TOYOTA' written across it. This will not seal any grease in.
best of luck,
Toby
1990 HDJ80 UK
___________________________________________________________
How much free photo storage do you get? Store your holiday
snaps for FREE with Yahoo! Photos http://uk.photos.yahoo.com
Just to follow up on this, Renate is after the dust cap that goes on
the end of the driveshaft output flange.
My suggestions was to try one or two of the 4x4 salvage yards to see if
they have from a Hilux or other Toyota model since they tend to share
some driveline components.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
