I think I'm in love <3
Joakim Forøysund
norway
It finally happened! I've wanted one for years, and now this one sits outside our home, waiting for some new parts. I need to fix a few minor issues before I bring it to mandatory roadworthy test. Then I can (hopefully) get the license plates back on.
HGAoKc5vb5rZjhYD1i3GPCPtiCcv5ceSX5f4dc53UM1WfLsNKHHVZ5T4ZgfTO6Y2LMW8qy7RfQlJ71WBBNEo_ZeVjs=w2400.jpg
Here she is, together with our Volvo.
gp0BrMFFr4GqR8gSTQRz3XR1N1g3ecaaDHoev-QJZAwMmwqgA0_ObFYdIsdJRVBuaWKxQhLDaoKUQAGmCq0QEMarIw=w2400.jpg
The missus has declared this one is hers, and I can just have the Volvo. :p
E1iuP13YRRqtF9X03AlX7wh1vpllQWv5zd0elADHY-UBuLjUgDTbB4z10S0uXKKdWwvTn8FBMbmrpxQM6f-HuIOtuw=w2400.jpg
jmAIXHPHEn8V60Gr-iuZPQz2Ea5yajlRQ63LDRX2EDjUimVepBmv4j_DjFWqU7oakVHMjfFb0k-6UcvIxw9rjxLjJw=w2400.jpg
It doesn't show here, but the interior needs some soap.
mcuZoGCki22vHJD3R8Xzb4qJBT_4osFtXM2f2aJuuC7hMUeg4yrYfdUSU3JeQKyDb-clouk5sKrf8LGE9RM4qROBkg=w2400.jpg
Z7E6wCfF5BSSn6NIohNjdBs_XmT6-XzuQE4LecbVa-FnzNJ4KfWS3ErBn3KH-Pr_JdJMFpO_1nZ8ajBlxX3ajOj-9U=w2400.jpg
TbmMFqcuKuhH3TnBk7JaXB46wLgJLlKM-k_VxRuabzIlP4KWkYy9s9PofSOCcLAoZmWsdx3qDmUHpBZnH5219FaWzU=w2400.jpg
Breather is clogged, and the seal probably needs to be replaced. There's oil everywhere. I have no clue how much is left inside there. Fresh drops showed after driving a short distance, so I took the chance to drive home.
AIOanQKxWEN8J3fKsm1M1lzrfxLjfsCSaniuJuect24aAGG_Mck9jhXzjnMbKOGvDtzWbY9IKrl4ZR4gA4byGTpfDE=w2400.jpg
Some rust, but it seems there's nothing major. Fluid Film will take care of this, I'm certain.
PK0iIq0jSyXlej0dFUuYiV-okMjQ9DR5HE9IJVmS5S5dhHElaV5DlggXhD0XvyyIdQ2q9_8KF7IVGKw8N34ln3tcTE=w2400.jpg
Underneath the round hole in the traverse is the only place I've found major rust. Here it has rusted through a few centimeters. I've inspected the entire frame as good as I can, and I can't find anything else alarming.
I ordered 20 kg worth of parts from Milner. All front bushings, water pump, belts and other service parts plus seal for the rear diff and new breathers. I also ordered a new radiator, just to be certain.
  • I already fixed a couple of electric faults on the rear lights
  • Wipers are working again (the link had come off), and I cleaned the interior.
  • A new digital radio is in place.
  • Painted the tow bar to make it look nicer and removed the spare wheel cover.
  • Pressure washed the frame inside and outside. The Kärcher gutter washer works very well for the purpose:
That's enough for now. See you lateer! :)
Enjoy it mate.. Iv said many times that i wished id never got rid of my 95.. Big regret ... Very capable and underrated Truck.... Its not a big job to do the diff pinion seal. And most of your rust looks like surface rust... a good clean up and plenty of paint should sort it....... All the best with it:thumbup:
Looks like a reasonable truck and no real rust to worry about. You’ve done well there. :clap:
I won’t ask if you’ve got a ‘cruiser grin’, just how wide it is. :icon-biggrin:
Looks l
looks like a lot of work has gone in, nice, enjoy.
