ID for 78 series front end part
cultivator
australia
Hello all. Appreciate if anyone can ID what part this missing bolt is from (right side of photo)
You can see the gaping hole in the bar under the coil spring.
Is this the Panhard rod ? Or sub-frame ? Lower control arm ? Chassis ?
Have had some varying opinions but trying to order the right bolt to re-fit now.
Many thanks for any help.
Couple of stainless steel zip ties she'll be right. Is there a bolt on the other side you can take out and measure?
Actually I just thought - I lost a bolt for my ignition coils the other day and did find it on the EPC here
You just enter your VIN or frame model and then it will show a guide of parts you can drill down through. Once you have the Toyota part number you have to go googling to find out the pitch/thread etc.
Thanks guys. Yeah, trying to work through it but best estimate from Toyota mechanic using photo was def Panhard rod bolt and should be easy enough to put new one in. Thanks for help everyone
Don't drive the truck anywhere. Very dangerous to use it like this.
Thanks Iwan. Safely parked and hoping easy enough to put new bolt in. Doesnt seem like access to the nut at the back under the coil spring so maybe its a threaded system for the bolt only.
Yep a captive nut or thread on the inside.
