- Mar 1, 2010
I've had to take off the inter cooler on my series 100 LC to cure an air con leak. Some debris has gone down the big flow and return air pipes, unavoidable as corrosion had gone past the pipe joints. Does all air from the inter cooler pass through the air filter before entering the engine please ? If so I need not be 100% careful cleaning the pipes out. There's a smudge of black oil in the pipes coming from turbo do you think?
Very difficult to trace the pipes without taking a lot to bits.
