My Prado just died on me and it will not start again. So far I've changed fuel filter, checked all sensors on the pump, check all fuses, tried starting while priming the fuel pump, no error codes from engine, no error codes on immobilizer, tried a different ecu, tried both keys and still no luck
It started for a couple of seconds when I gave the split valve direct power and they died. I know there is fuel all the to the pump.
I haven't checked the TPS og crankshaft position sensor, but they are not known to be broken as far as I know.
Fuel lines looks ok.
Any suggestions? It's a 1997 with manual gearbox
