Hi Kirk,
The breathers will sweat a little bit - the key thing is to make sure
that the small valve at the top doesn't get blocked when dust is
attractged to the wet oil - pull the metal end off with some pliers and
remove the spring and rubber seal - this will help it breath a little
better.
Ideally extend the breather up into the enging bay or all the way to
the air box.
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
better.
the air box.
