LCOOL "1HD-FT Performance Adjustments"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Hi Tomaz,
The 1HD-FT engine was de-tuned slightly off boost in order to try to reduce the emissions, as a result when compared to the 12valve engine it runs like a dog until the turbo boost builds up.
If you read the articles you will find that some cars will benefit greatly from the tweaks and others won't.
At the end of the day these engines can handle a lot of horse power, however when tweaking the fuelling you always need to be conscious of not over fuelling it, leading to higher head temps and sub sequential damage. Ideally you need to check the temps using an Exhaust Gas Temperature probe and guauge, however as long as it isn't spewing out loads of black smoke you should be reasonably safe.
I have tweaked a lot of pumps and find a massive difference in the state of tune of engines, even between ones of the same age and mileage. I had a lovely 1994 12 valve the other day that the owner was complaining was gutless and it was averaging 180miles to a tank and just through some minor tweaking we have got more power and it is returning around 280miles to a tank when towing a heavy trailer.
Some of the tweaks in the article can be applied to the 12valve engine as well. I have been slowly tweaking my own 12valve particularly with the aim of removing a flat spot after the turbo kicks in and it now picks up and pulls throughout the rev range and runs better than some intercooled 80s I have come across. Having said that I'm planning on intercooling it in the next couple of weeks which should be interesting :)
Julian
Email: [Email address removed]
Tel:=A0+44 (0)845 508 6863
There was no noticeable increase in black smoke after the adjustment.
Ian
and I have some...sometimes like a cloud behind me...some suspicious
adjustment from some suspicious turbo mechanic ...with tree words:made in
Norway....
Lubo
On Fri, Aug 29, 2008 at 6:31 PM, Ian Rubie <[Email address removed]> wrote:
> Perhaps Ian Rubie can tell us if he noticed any increase in black smoke
>> under load after the pump adjustment?
> Ian
> European Land Cruiser Owners Mailing List
> Further Info: http://www.landcruisers.info/lists/
Yes mine with these AAI big turbo and intercooler kit makes some very
big smokes if I push hard on the mushroom with my right foot. So they
tells me unless you have all these the modern electronique injection
shit you will smoke more if you make power.
I leave you good bye with my big black cloud like the Lubo did. But I
leave you faster!
2008/8/30 Lubomir Kolev <[Email address removed]>:
