- Apr 10, 2016
want to change indicator bulbs to LED. But they flash too fast. Do i need a resistor? One per side or one each lamp? Thanks
Yes I think I have those in my rear flashers, I just put them in and worked okUsing a nominal 13.5v the resistance of each (21w) bulb is around 7.7ohm. Don't think it'll be that critical if you go higher by a few ohms as LED's draw little current but too high and the relay could 'see' an open circuit as in a dead bulb. Can't you by replacement LED bulbs with the resistance built in so it's just plug and play?
Everything is 24v Rich except the radio which runs to just one batteryAre your lamps 12 or 24v Ben? If 12v and based on that 7.7 ohms then, the resistance overall works out at just shy of 2 ohms at say 50 watts if it was constantly running. At a 50% duty cycle (on, off,on,off) I expect a 25W one wouldn't get especially hot unless you left your indicators on for hours on end.
That would be the ideal solution, though fitting a resistor shouldn't be expensive or difficult it does involve a bit of work whereas that would be plug and play.I’m pretty sure you can but an led flasher relay or an adjustable flasher relay so you wouldn’t need resistors
Were you able to find a 24v flasher?That would be the ideal solution, though fitting a resistor shouldn't be expensive or difficult it does involve a bit of work whereas that would be plug and play.
