Hi David,
Don=92t know a huge amount about diesel brake systems but a few thoughts.
Is the servo working currently and is the vacuum pump operating consistent
and reliable? Reason I am thinking about the pump is perhaps you are not
getting sufficient vacuum from the pump so the slow application is OK but
rapid application is not? Hard to check on a diesel, on a petrol it is
usually very easy to put a gauge on with a tee somewhere.
The MOT does by require only a slow application of the brakes without
locking them up and then slow release.
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
Behalf Of David Charman
Sent: 30 March 2007 11:46
To: [Email address removed]
Subject: [ELCO] LJ 70 Brakes
The brakes on my 70 have always been poor, when I got it the pedal was solid
so I found a S/H servo which seemed to sort it out. However recently the
have got worse. Basics are fine pads/ discs, drums/ shoes manually adjusted,
brakes bled out buy various methods OK, vacuum pump is working and holding
vacuum. The strange part is if I apply the brakes normally they are poor, if
I apply them very slowly the braking effect build up and they are fine, if I
pump the pedal they are fine, the pedal feels hard normally but the second 2
options is OK. Strangely it has passed the MOT no problems both years even
with servo not working? My wife used it yesterday and was not impressed!!
Any thoughts??
David
LJ70 Gatwick
Colway A/T's
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.22/739 - Release Date: 29/03/2007
13:36
13:36
