LJ78 Parado
Shahab Hanif Khan
pakistan
Hi everyone,
I bought in 2013 LJ78 1991 Land cruiser Parado
It was on 2L engine without turbo and MT
now I have upgraded it to 1KZ-TE with AT
All the suspensions and coil springs are changed, Axles are changed , Brake discs and drums with pads etc.. are changed .
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Guys I am facing downshift problem from 3rd gear to 2nd gear , my TLC gear box start jolting while downshifting the gear from 3rd to 2nd. can any one suggest me what to check?
[/URL][/IMG]
It sounds like an ecu issue. Which 1KZ te did you get cause this engine comes in surf , prado and Hiace as well. The 1kz te , transmission is controlled via its ecu. ?
Thanks for the reply
Engine bought from the open market, no idea it is from which car.
The A/T if from parado 1995.
I understand, I think you just need to try different ecu's . However it could also be something as simple as the AT transmission setting. I notice you are in Pakistan just as me , Private message me your cell no and Maybe we can talk and sort this out. I think we have a mutual friend Hanif Bhatti as well.
Thanks for the Reply I have swapped couple of ECUs already, Now I am thinking to check the Solenoids.
Yes I am friend of HB sir , but I dont know how to PM you in this group?
will appreciate if you can PM me . Thanks
