Ln65 rear e locker into lj78 front housing??
everyinchmatters
new_zealand
Hey all. I have a lj78 that's been fully kz manual swapped. Diffs and all. Am running a rear Heaton e locker and have just been offered a factory e locker out of a ln65. Have heard before that you can run a rear diff nugget in your front diff with the front bearings and gears but I am sceptical on that info. Any help would be amazing
If it's a 8" axle centre on the ln, then it'll fit the lj front. They're standard interchangeable components. But you need to just swap out the open diff to the e locker and add to your gears.
Rear diff centre is central, front diff is above centre so a down grade to fit the rear on the front.
A kz in a lj is proper thug life! Will always bring a smile to your face without fail. More so with the lj70 4.88 gearing! :thumbup:
