Right, here we go.
If we are talking a diesel cruiser there is no need for a pusher pump, the
cruiser pump is a dual stage one that sucks the fuel up and then pressurises
it for the injectors. Ali is not good for tanks, it hardens with either age
or work so in time it will crack with stress. Steel is the better option,
unfortunately, both for lifespan and repair.
My thoughts are a tank where the spare fits on UK models, a changeover valve
to dictate which tank fuel is drawn from with a rocker switch to select. The
same rocker switch will switch over the fuel guage to read on whichever tank
is being used. I also like the Toyota dual filler, made for the job and
looks the part.
Regards, Clive.
On 9/20/05, aclbell <[Email address removed]> wrote:
> Hi Julian,
> I have a frontrunner XLR tank on my petrol cruiser in SA. It is 168
> litres and has a transfer pump controlled by a switch in the cab. They
> are good value at a mere =A3350 plus about 50 quid fitting (in SA prices).
> Alas, I'm currently working in the UK - but will be going back to SA in
> Feb. When I do go, I'm planning on buying another XLR and shipping it
> back to the UK for use on my diesel cruiser over here. If this flies,
> I'll ask the question on the list at the time and see if anyone else
> wants one.
> Cheers for now,
> Andy
> -----Original Message-----
> From: [Email address removed] [mailto:[Email address removed]]
> On Behalf Of Julian Voelcker
> Sent: 20 September 2005 14:00
> To: [Email address removed]
> Subject: Re: [ELCO] LRFT's
> Hi Clive,
> > Some weeks ago One of the group was talking about getting long range
> > fuel tanks from Australia. Has this gone any further?
> Not sure about Australia, but Andy Bell might be able to help out with
> getting some from FrontRunner in SA.
> I might be ordering one in the next month or two for someone so may be
> able to double up on the order.
> Regards,
> Julian Voelcker
> Mobile: 07971 540362
> Cirencester, United Kingdom
> 1994 HDJ80, 2.5" OME Lift
> European Land Cruiser Owners Mailing List
> Further Info:
http://www.landcruisers.info/lists/
> Further Info:
