Make me an offer - many parts for sale
SimonD
australia
I'm having a large clear out of kit and essentially, before I put anything on ebay I want to see if anyone here would like anything. Essentially I just want you to PM me an offer and if I like it I will sell to you. Some of the kit is quite heavy or large but I can take it to the Adventure Overland Show to handover, otherwise we'll need to agree to use forum members to pass equipment on as I'm in London. I do travel a little bit at the moment so let's see. On smaller stuff postage will be ok. I'll be adding to the for sale as I go. I've put the pics on my photo site so you can zoom in and check part numbers etc.
All of the kit pics for sale can be found HERE:
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-hhTBbLB
First up - make me an offer for crown wheel and pinion front and rear kits - not complete but mostly there. The Aussie supplier sent me the wrong ones - the bearings are for NON-LOCKER diffs so I was unable to fit it. So pretty much as new [it is mainly bits of grease on the bearings not rust]. There are some pinion spacers and other gubbins including [I think] my old bearings. The CWPs look in good order so may make a good spare for someone. All Koyo bearings so the right stuff. Couple of gaskets too but i can't guarantee they are all there. Only reason I took these out was that I re-geared my front and rear diffs with nitro. I would like an offer on the whole lot rather than individually.
Second on the list is the rear light guards: https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-vXs5Kkm/A . Look closely and you can see a couple of areas where it has rusted so not pristine by any means.
Third on the list is a bit from my old exhaust: https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-q2zGTfp/A
I'm open to all offers. UK only though.
The water tank has been sold. More items will be posted tonight including 2/3 of a cargo barrier, caster correction bushes, Kaymar accessory, brake lines, fabbed console etc.
Keeping an eye on here given you are so close to me :)
Four National Luna switched lights with two mounted on fabricated brackets and the other with a long DIN extension. Pretty weather resistant and low power but NOT LED.
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-vJntkg6/A
Also these two steel fabricated pockets for free - the PO made these and put them on the rear doors for his kids books. They are built to survive armageddon - someone may have a use for them.
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-sLhL5FP/A
The PO fabbed a cubby box for centre console use but we removed it because it was too close to the auto low and we wanted a fridge there. It's big and well made but may just be better utilised as a secure storage box or perhaps a console in a manual. You can see the mounting holes in it but note that there is a purpose made flat hole in the lower right where the previous owner allowed cables in [or a restraint - i can't remember!]
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-zBk4sdB/A
and
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-6pBmpQF/A
Two unused rear springs made by Ridepro for Darren at Autocraft. No longer made. They were sent to me in error as I needed +400kg springs so these were only fitted once [gave me about a 2.5 inch lift or so]. I'm chasing the specs in Oz but may not get them. I know they are better than stock but not so good for a heavily laden land cruiser.
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-jmN5rSd/A
and
https://www.kiangazi.com/Overland/Toyota-for-sale/n-jDz2LP/i-wtwhXDN/A
Update from supplier:
7501 is 200kg constant load intermediate rears.
They should be 19.mm dia wire on thicker section with powdercoat.
HD would be 20.4mm and 7511 part number.
