CAT
- Mar 22, 2010
Had a go at checking the pump timing at TDC. In my Max Ellery manual the reading for Europe is 0.39 - 0.43mm, for other countries it is 0.58-0.62mm. Tried it at the Europe setting and it definitely didn't like it so then thought because the pump is from NZ I should set it to the other countries reading? Got some slight engine knock with it set to 0.60mm, may have to trick around with it a bit more. It still runs nice well, wonder if the knock is being caused by something else? Had a few test drives up and down the road, it pulls alright, more speed that I could ever safely need but good to have it in reserve. EGTs seem fine so far, I'm going to be a while tuning things and getting the boost up where it should be. Also the tacho is off so will need to adjust it at some stage.
