Beau
- Jan 28, 2011
Quick question,
Currently have a marine deep cycle battery in the truck as the one that was there failed a few days ago. It's 650cca. Is it safe to run in parallel with my other regular battery?
Are there any pros/cons in running a marine deep cycle battery like this?
I read they don't like heavy amperage draws like when starting, though I should add this is the one on the drivers side, the starter cable is run to the regular battery, though I'm not sure this even matters because it's a parallel circuit. As you can see, I'm not too good when it comes to electrics...
What's you guys view?
